mrman99 Posted May 29, 2004 Report Posted May 29, 2004 Need some advice on spliting the case. I took off both side covers off, and unbolted the screws on top and bottom. took off the flywheel, stator plate, kickstart gear and spring. the case doesn't want to split. is there anything else i need to remove. I banged on it a little bit, thinking it might be the seals sticking. but no go. Any suggestions... Quote
Oilsmoke Posted May 29, 2004 Report Posted May 29, 2004 also use a rubber mallet and tap it hard all over to break loose the case sealant they use. Quote
frocashmoney24 Posted May 29, 2004 Report Posted May 29, 2004 make sure everything connecting the two cases is off, did u take the topend off first? use a arubber mallet like he said, to tape ite cases apart, and a screwdriver carefully! Quote
sweetshee4312 Posted May 30, 2004 Report Posted May 30, 2004 before u start doing all this shit, do u have a manual or something, casue theres lots of shit to take off, id sugest getting a clymer before u keep going Quote
evil Posted May 30, 2004 Report Posted May 30, 2004 ohh and drain the oil invest in a clymers manuel if you dont allready have one. its easier to have it infront of you then to keep running back and forth from the garage to the computer. is this the first one your doing ? Quote
mrman99 Posted May 30, 2004 Author Report Posted May 30, 2004 yep its my first time...and nope don't have a manual...anyone know where i can pick one up cheap? Quote
fixitrod Posted May 30, 2004 Report Posted May 30, 2004 Meat has a step by step on his web page. I used it about 4 yrs ago when I did mine for the first time. Here's the link http://www.thebansheezone.com/Bansheezone/BottomEnd.htm You can get a service manual at the dealship. Quote
