02_banshee Posted May 21, 2004 Report Posted May 21, 2004 i use belray always have always will even for gearbox.. but ive brought some rock oil.. gunna give that a go in gearbox.. i use rocoil premix smells the best Quote
Timmy301 Posted May 21, 2004 Report Posted May 21, 2004 The ProFlow filter has 2 stages. Do ya'll recommend spraying both layers? no no no Just spray the outer one!!!! Quote
MotulMonsta Posted May 23, 2004 Report Posted May 23, 2004 No dude, oil them both. Filter will not work without oil. Dirt will pass through. Always..if you care about the well being of your engine..Always oil your filters..both layers even your K&N's. Open pore foam type filters depend on the oil to sit in the cavities of the foam and trap dirt as it works it's way into the filter. Withoil the oil, dirt will eventualy find a way through and into your motor, cloging up your carbs, getting into your crank bearings sandblasting everything inside and causing premature wear on every part inside that motor. Quote
SANDSTAR Posted May 27, 2004 Report Posted May 27, 2004 I like the K&N filter oil. It is red, so you can see the spots you have missed. Quote
blk02banshee Posted May 30, 2004 Report Posted May 30, 2004 Maxima fab-1. Very evil stuff . That shit just kicks ass. Quote
