Exhaust Crackles Out Of Right.
Sounds like carb sync. I tinkered with synchronizing the slides on the stock carbs endlessly and never could get both cylinders to fire the same. One would always crackle more than the other. Maybe aftermarket carbs are better due to the choke system. I've now switched to the CV system and it feels great to hear both cylinders firing in unison.
You're right carb synch is a pain with the stockers.Theres a rule with them to adjust the left never the right.With fresh gapped plugs it still does the same crackle.Brand new stator from ricky in her.
I have heard this rule but I could find now way aorund it? Care to clarify?
On the left side the slide operated fine, but the right slide would not pull up untill later on because it needed to be tightened. So I tightened it..This is wrong? Now they both pull up at the same time but I think I may be having problems with the TORS.
