I think my shee's ignition is wanting to be replaced. I grabbed one of the plug wires to make sure it was down all the way (seem to be missing on one cylinder at idle) and it shocked me. Do they leak that much or is it time for new wires?
I am thinking about Nology wires, I run one on my 350R, but at $80 a pair they aren't cheap. Also are there any upgrades to the stock coil? I know nology makes a motorcycle coil also but who knows if it works with a banshee.
I'm trying to stay on somewhat of a budget so if there are no real benefits of upgrading the coil/wires I may get a stock replacement. I'm not totally ruling out a dyna ignition. Are they the bee's knees or are they not worth the money? I'm not interested in PVL since I need to run lights.
We learn something new every day
Don't grab plug leads, they will shock you. :wacko:
Does your banshee only miss @ idle or under throttle as well.
Hot or cold?
Make sure you check out your carbs and narrow down the problem before you start forking out cash.
