BrokeStonedBiker Posted April 25, 2004 Report Posted April 25, 2004 about the floater bowls being on backwards. ther left one could be on the right carb abd vice verce. on the side with the carb, look at the floater bowl there should be a little broze or copper brass looking ball on it facing towards the engine side. i got fatties and i run 260 mains with a stock bore so i think something is off but i dont know, if it ran GOOD last season then it should at least run, right? check the floater bowl i assume you know how to tune the carbs, and check the stator. but check them bowls first. Quote
BrokeStonedBiker Posted April 25, 2004 Report Posted April 25, 2004 lol i cant get a sentance right for some reason. lol i mean about the floater bowls being on backwards. the left one could be on the right carb abd vice verce. on the side with the choke, look at the floater bowl, there should be a little broze or copper brass looking ball on it facing towards the engine side. Quote
H300F Posted April 25, 2004 Report Posted April 25, 2004 Get size 30 pilots It will help for now if you hold the choke out after its started until it starts to get warm. Quote
sandbuzzard Posted April 25, 2004 Report Posted April 25, 2004 i did the spark test. grounded out the plug on the engine nut i only got one spark out of 7 kicks. i tested the coil with an ohms meter, useing the same steps in my clymers book. Spark Plug Tops.... Quote
fox420girl Posted April 26, 2004 Author Report Posted April 26, 2004 fixed!! thank you for all your help. so i have spark now!! the problem was one of the previous owners had removed the main key switch and hadnt fixed the wires together well. so i cut the wires new and bell caped them. and way to go me!! it sparked very well on a weak kick. i put my clean carbs back on and everything and kicked it over and it started up on the first kick!! however it still dosent idel very well once warm. should i change one of my jet settings? thank you for all your help. i still have yet to put the tors removal kit on. Quote
