sheerider4life Posted April 23, 2004 Report Posted April 23, 2004 I am running motor oil in the tranny...penzoil...do i need to run gear oil...will it not break then Quote
TREELIZARD Posted April 23, 2004 Report Posted April 23, 2004 the motor oil wont cause your tranny to break unless your oil level is really low and the gears get really hot. but if you running the tranny low on oil it will damage it no matter what kind of oil you put in it. it is ok to run regular car oil as long as it doesnt contain any friction modifires or is labeled energy conserving because it can cause your clutch to slip. castrol GTX20w-50 is an example of a good car oil that you can run. also automatic transmission fulid type F is really good to run. its also known as ATF type F Quote
ledofthezep Posted April 23, 2004 Report Posted April 23, 2004 I've ran Valvoline 10w30 since day one & haven't had any problems. Quote
frocashmoney24 Posted April 23, 2004 Report Posted April 23, 2004 maybe something in ur tranny is fucked up...just athought Quote
sandbuzzard Posted April 24, 2004 Report Posted April 24, 2004 You think Quacker State 10w-30 would be cool to run? Quote
holeshotkid Posted April 24, 2004 Report Posted April 24, 2004 You think Quacker State 10w-30 would be cool to run? Isn't that Mallard Oil (winter blend)... Quote
sandbuzzard Posted April 25, 2004 Report Posted April 25, 2004 LOL, just seen it, proof reading might help .... Quote
SDD Posted April 25, 2004 Report Posted April 25, 2004 I am running motor oil in the tranny...penzoil...do i need to run gear oil...will it not break then Depending on how old your motor is and how much power you put out the cases could need replacement. What happens is the races where the tranny bearings are held get stretched out and oblonged. When you hit the gas eventually the gears are just transfering power through the tips of the gear teeth. I would check the gears for play when the motor is apart. I also like heavier weight gear oil apposed to motor oil for the transmission. Would you put motor oil in the transmission of your truck? Maybe it's just me... but I wouldn't Quote
holeshotkid Posted April 25, 2004 Report Posted April 25, 2004 LOL, just seen it, proof reading might help .... Sorry, I couldn't help myself. No offense, I'm just kind of a smart arse at times. Quote
sandbuzzard Posted April 25, 2004 Report Posted April 25, 2004 LOL, just seen it, proof reading might help .... Sorry, I couldn't help myself. No offense, I'm just kind of a smart arse at times. No problem, I found it funny myself. You have to be able to laugh at yourself once in a while..... Quote
