Bensshee Posted April 23, 2004 Report Posted April 23, 2004 If you have had a crank trued and welded, can you retrue it and reweld it if it was done wrong the first time? Quote
boonman Posted April 23, 2004 Report Posted April 23, 2004 yep. Just grind the old weld off, anc re-true it, and weld it again. Although, I doubt someone in therir right mind would weld a crank if it wasn;t perfect..... Quote
Bensshee Posted April 23, 2004 Author Report Posted April 23, 2004 Well it happened and I had to have it fixed. I won't say who welded it or what crank it was, but it happened to me. That was not the only problem I had, the port job that was done to match the crank was done wrong as well. The worst part it took a while to figure out the problem. I had a well known builder do the work. Quote
wimpywade94 Posted April 23, 2004 Report Posted April 23, 2004 so when you weld a crank, what exactly do you weld? and what is truing it? just a couple questions cause i may have to have it done, later wade Quote
boonman Posted April 26, 2004 Report Posted April 26, 2004 Truing tha crank is referring to making sure the crank is in phase. In a banshee, this means that the rod pins are exactly 180 degrees apart in 1 crank rotation. Once this is accomplished, the pins are welded to the outside of the crank. Banshee cranks are pressed together. (as are many other cranks) Because of this, there isn't much that holds them from coming out of phase, and/or seperating. Welding the pins prevents this from happening... Quote
knight_ripper Posted April 28, 2004 Report Posted April 28, 2004 when are the stealers gonna start reading Forums...and start fixin their stuff. Damn Stealers Quote
wansomordis Posted May 8, 2004 Report Posted May 8, 2004 (edited) I won't say who welded it or what crank it was, but it happened to me. I don't understand why you won't say who done the piss poor work ??? If I have a problem with a pro shop then I'm gonna let EVERYBODY know.. Thats why we send thing to them is because they are suppose to know what there doing. And by you letting them take your money and waste your time you to them are a sucker...Why not help the next guy deciding where to send there crank or motor the hassle you went through.... As with me the only problem I have is with Trinity.. They make damn good parts but there customer service blows... Edited May 8, 2004 by wansomordis Quote
Bensshee Posted May 9, 2004 Author Report Posted May 9, 2004 Nobody is perfect, and he has a family to support. I just had a bad experience I don't want to bad mouth someone through a computer. Quote
jrfastbanshee Posted May 9, 2004 Report Posted May 9, 2004 I have a family to support too and I don't want to spend hundreds of dollars for work just to spend hundreds more to get it fixed! If he is well know than he should stand behind his work right? Either you loose hundreds for picking the wrong guy or he looses for not doing it right. I would expect it done right or have it fixed at no charge...but I realize that is just a dream with most builders. You don't need to bad mouth...just advise us of your experience. Just my opinion... Quote
