239banshee Posted April 22, 2004 Report Share Posted April 22, 2004 how do the seals go in on the 2 into 1 pipe.theres no groove Quote Link to comment Share on other sites More sharing options...
pimp559 Posted April 22, 2004 Report Share Posted April 22, 2004 If there is no groove run a small bead of high temp silicone all the way around inside the corner of the header flange. Make sure you let it dry before you start it. Quote Link to comment Share on other sites More sharing options...
frocashmoney24 Posted April 22, 2004 Report Share Posted April 22, 2004 good luck bro, ive put all kinds of sealent on mine and it still leaks, im tinkin bout gettin exhaust tape Quote Link to comment Share on other sites More sharing options...
pimp559 Posted April 23, 2004 Report Share Posted April 23, 2004 You could also go to your local auto parts store and have them match up an o-ring where I said to put the silicone. You could put it in there and try it if the silicone doesn't work. Quote Link to comment Share on other sites More sharing options...
Foobie Posted April 26, 2004 Report Share Posted April 26, 2004 There is no where to put an o-ring. Like Pimp said. Use High temp silicone. I ran a good bead on the inside of the pipe about 1/4 inch in. Let it set up then put it together. Now if your pipe is like mine, when everthing is mounted up there is a gap where the pipe meets the cylinder, only about an 1/8-1/4 inch. I put some silicone on my finger and mushed it into any gaps I found. I now have no leaking problems. Dustin Quote Link to comment Share on other sites More sharing options...
