using what method can you change your gear the fastest, for example going from first to second or second to first, so that you do not loose momentom
I start by slightly letting off the gas to ease the pressure on the transmission gears, then I lift my left toes up to hit second. It usually works. I do just the opposite to shift down.
No, he is using the clutch...if you dont use the clutch...then your gonna eat them gears up before u can say "use the clutch" becasue i have broke 2 3rd/4th pinion gears...and i was using the clutch too.....always have...and it helps from not shifting..if you dont use your clutch then you wont shift so easy, you will be craming the gears back and forth....USE the clutch at all time...if not you will pay for it.
uhhh. i never use the clutch when im dragging and i have never had 1 problem with this on any of my bikes. i dont think you wanna jam it down a gear without a clutch. when im in the trails or something like that i always use it, shifting up or down. straight line dragging tho i dont use it.
