It is illegal to use the stock air filter after you have posted on this site more than 50 times :angry: Replace-replace-replace-lose that whole set-up-any after market set-up is better than the stock garbage
I would clean it with fire. Put it in the fire and watch all the dirt go away. Then go get a K&N. If you just have to use that stock POS wash it with dawn and warm water, shake out and let dry. Install and you are ready to go. Why do I feel like I just told someone how to destroy his motor. :o:(
dont lie to him itsaripper, you cant clean the stock filter.....they are disposable filters. You just throw them away and buy an aftermarket setup.
the plan was to not spend a thing and get the duncan racing kit, which has everything in it... so......ill leave the filthy fecker on  :rolleyes:
just ask yourself, "do I really need an airfilter?" if not, then just forget about the whole damn thing. :D
Allright man, Soak the filter in kerosene as it sits in the kero push it around to help get the dirt out. Take it out,squeeze out kero then shake out any extra.Using a rag squeeze the foam filter with the rag til no kero shows on the rag.Then using your favorite 2-stroke oil lightly coat it and you're good.
