yan Posted April 8, 2004 Report Posted April 8, 2004 i use 20 liters of gas with 500ml of oil is that good 10 liters gas 250ml oil 5 liters gas 125ml oil 2.5 liters gas 60ml oil how much gas fits in the banshee gas tank also does anyone fill their banshee gas tank at the gas station and then put the oil stright into the atv tank depending on how much gas you put in. so instead on carrying a big red spear tank all i would have to carry is a little oil tank. what is your oil gas ratio mixture. no lid on air box should i stay away from mud and water Quote
Nighty Posted April 8, 2004 Report Posted April 8, 2004 mix ratio's depend on your brand and type of oil. my mix ratio is 1:32 and this ratio is a good rule of thumb. 1:25 is a bit over oiled but it is what the banshee manual suggests. i sometimes fill my banshee at the gas station and then poor oil in the tank. never had problems.. castrol tts rules mixes nicely. if you ever gonna do that make sure to leave room in the tank for the oil my experience: no lid = stay away from mud and watter. stand would be O.K. but i like to see my AIRBOX clean. that way i'm more sure the air is really clean when it goes trough my engine. i dont really trust that K&N setup i have Quote
DIRTMAN350 Posted April 12, 2004 Report Posted April 12, 2004 run your premix at 32:1. i usually mix mine in a 2gal can with the oil in it so that way when adding gas it will get mixed up good. Quote
