StreetRacer4Eva99 Posted March 9, 2004 Report Posted March 9, 2004 Well i'm new to the forum and within a month hopefully i'll be joining most of you in being a proud owner of a shee. I would like to know what mods should be my first and money is not really an issue. Also i would like to know of any trouble shooting issues that i might encounter or any problems i should look out for.I woud appreciate any info so please be open about it. Thanks Quote
Ultimateduner Posted March 9, 2004 Report Posted March 9, 2004 I would buy a good set of aftermarket pipes and an airfilter. Quote
nater006 Posted March 9, 2004 Report Posted March 9, 2004 Pipes and an intake (or just a K&N). You can drop the airbox lid and get some good airflow. If those don't break yer wallet... consider some of the minor stuff like a stainless steel water pump impeller cause the stocker will probably break eventually. Quote
brugal Posted March 9, 2004 Report Posted March 9, 2004 The first thing you should do is buy a CLYMER service,repair ,maintenance book and learn about your quad. Quote
sredish Posted March 9, 2004 Report Posted March 9, 2004 This The first thing you should do is buy a CLYMER service,repair ,maintenance book and learn about your quad. Then this... I would buy a good set of aftermarket pipes and an airfilter. Get it? Quote
bignasty1 Posted March 9, 2004 Report Posted March 9, 2004 i recomend the performance items in this order. 1. noss machine cool head. www.nossmachine.com (have a look goo shit) 2. air filter, pipes. 3. tires. 4.have some one cut you a -2 swingarm 5.some nerf bars.(if ya dont race then they'll help you keep from get'n hung on trees) 6. suspension thats about it then you can just have fun and as thigns wear out on the motor down the road look into a 4 mill stroker. Quote
XTShee Posted March 9, 2004 Report Posted March 9, 2004 Remember to re-jet for the pipes and airfilter. Quote
StreetRacer4Eva99 Posted March 10, 2004 Author Report Posted March 10, 2004 What Jet-kit should i get? Also what cc domes should i get for the shee? So far my mod plans are as follows....Toomey T6 Pipes and silencers....K&N air filter....White brothers boost bottle....and Boyesen Reeds...what modifications should follow the ones mentioned? Quote
sredish Posted March 10, 2004 Report Posted March 10, 2004 What Jet-kit should i get? Also what cc domes should i get for the shee? So far my mod plans are as follows....Toomey T6 Pipes and silencers....K&N air filter....White brothers boost bottle....and Boyesen Reeds...what modifications should follow the ones mentioned? Don't get a "Jet kit". Go to the dealer or CarbParts.com and order the necessary jets. You'll save some money and don't get parts you don't need. Quote
LegendSS28 Posted March 10, 2004 Report Posted March 10, 2004 Don't bother wasting your time or money on a boost bottle. They don't do anything Quote
StreetRacer4Eva99 Posted March 10, 2004 Author Report Posted March 10, 2004 Yea but when i continue modding my shee i will have to change the jets more often and i don't want to be ordering them everytime i put something else on. Also what reeds do u recommend? Quote
bignasty1 Posted March 10, 2004 Report Posted March 10, 2004 i wouldnt go with the t-6. from what i hear they dont to all to well with porting. and i would really recomend either paul turner mid pipes they are the best pipe for "all around riding " i have ever rode. other than that ur doin good. Quote
richybanshee Posted March 10, 2004 Report Posted March 10, 2004 This is what I would do: 1. forget about the boost bottle 2. Toomey TR6 chrome pipe kit (or the set of pipes, tubes and silencers If you want to make the carb tuning yourself. You will need to buy the K&N filter for better performance) 3. timming plate advance 3 to 4 degrees 4. VForce reed cages 5. aftermarket head with 19cc or 20cc domes if you ride at sea level or 1000 feet on premiun gas ( Pro-design or any other brand) 6. set of good tires to put all that new power to the ground My guess is that with this mods you can be like in the 45 to 50 hp A stock banshee has like 32 to 34hp aprox. If you need more power, consider porting. I reed in Dirt Wheels mag an article on a Mission Yamaha's banshee it had T5's, VForce reeds, Head moded by them for 150 psi and their porting work, running with VP fuel and made 59hp to the rear wheels. Everything else was stock. Quote
