Basically have a whole engine here that I'm going to be parting out. Everything is still here except the cases. Going to be putting the stuff on ebay shortly and expect to get ebay prices for them. Figured I'd put up the notice here if anyone wants to cut out the whole ebay thing.
Trans - good shape, little surface rust, needs new bearings, comes with a good front sprocket
Crank - still in good shape and tolerance levels check out, looks like bearing went bad on it on the one outer, only inner race left on it
Cylinders - dont know exact bore, can go get it mic'd if wanted, lots of meat on the sleeves still
Might be selling another set of cylinders that need a .40 overbore, and I have one of the pistons, rings, wristpin, and clips for (need the other side and wristpin bearings to complete it). Might keep these for a backup set.
Stator, flywheel, clutch assembly, parts or whole, shift drum, forks and shafts, clutch cover (probably going to polish it), and all the other parts that go with an engine. If I didnt name it, I probably have it.
zilladude: got the shift drum, but the shift star is gone to the modified world. Let me know if you still need just the drum, or any other parts of the tranny.
Cheezehead: I've got a couple stator covers: one off the engine I just got thats perfect, one that is on my original engine that I threw a chain and it cracked the rear of the stator cover (all there and with a little miracle glue you could make it look perfect), and the one from this engine that I'm parting out that has 2 of the ribs that go over the sprocket cut out of it. Let me know
Demsy: I've got like 4 or 6 boots laying around from various engines and top ends. What are they worth to ya?
bump:
cases, shift star, cylinders, and flywheel are gone.
Rest of the engine is still here. I have 3 or 4 reed cage sets and a couple good boots laying around here somewhere as well I believe.
yeah, it happens. Ended up getting a complete running engine so I figured I'd part this one out.
Pm me bansheeboy, and we'll work something out.
