SiCkBaNsHeE_990 Posted February 26, 2004 Report Posted February 26, 2004 I just got done putting on a twist throttle. I went to start it up and kicked it and nothing happend. I tryed and tryed again and again. I check all my connections and it had gas. The spark plugs are good. Before i put this on it started in one kick yesterday. Anyone got any suggestions? Quote
sand rocket Posted February 26, 2004 Report Posted February 26, 2004 double check and make sure that you turned on the petcok. Sound dumb but it happen to everyone! Quote
Banchetta Posted February 26, 2004 Report Posted February 26, 2004 Make sure your slides are all the way down and the throttle isn't hangin up a little... Quote
SiCkBaNsHeE_990 Posted February 26, 2004 Author Report Posted February 26, 2004 ya i adjusted them and they are sitting all the way down. Quote
JayFressh Posted February 26, 2004 Report Posted February 26, 2004 Check your electrical connections. Do you still have your TORS on? Quote
SiCkBaNsHeE_990 Posted February 26, 2004 Author Report Posted February 26, 2004 nope no tors i installed a twist throttle. and everything i could see was pluged in. Quote
JayFressh Posted February 26, 2004 Report Posted February 26, 2004 go here > TORS and make sure you disconnected the right things. Like suggested before make sure slides are moving correctly. Also are you getting gas? Check to see you are getting gas. Check your plugs with the new twist throttle did ya just flood it? Quote
sand rocket Posted February 26, 2004 Report Posted February 26, 2004 is the little black box on the left side by the tank pluged in. try unplugging that one and try it Quote
MotulMonsta Posted February 26, 2004 Report Posted February 26, 2004 Quick fix..next to the coil...where the plug wires come from..there is the TOR's box. unplug it. if it stars that's it. cap of the conector and throw away that box. it's garbage. the tors is a 3 pin plug. Quote
SiCkBaNsHeE_990 Posted February 26, 2004 Author Report Posted February 26, 2004 yes its getting gas and all that stuff ill go get rid of those tors wires and ill try the plugin thingy. Quote
MotulMonsta Posted February 26, 2004 Report Posted February 26, 2004 On the stock thumb throttle thee is a contct switch..that goes to the tors system. I assume the quad was running before you installed the twist throttle. It might be flooded. You will get spark to the plugs with a fualty tors but it won't stay on. I one time spent a half hour pissed off trying to start my Shee before I realised my tether was unplugged. Let's not forget about all the 100 or so times I forgot to turn the fuel on and halfway around the track my quad would die. It's those simple things that cause the biggest headaces. Quote
Banchetta Posted February 26, 2004 Report Posted February 26, 2004 Are you even getting spark?? Check the plugs and not the headlights, two separate circuits... Quote
SiCkBaNsHeE_990 Posted February 26, 2004 Author Report Posted February 26, 2004 i will have to check everything and make sure. This stuff pisses me off. Quote
MotulMonsta Posted February 26, 2004 Report Posted February 26, 2004 I was stuck at the track last weekend because my Banshee threw a hissy fit and decided not to start after she was running SO good. an hour later after I was good and pissed off I decided to try one more time and she started like a champ in the first kick. It pissed me off. Quote
