I just got done putting on a twist throttle. I went to start it up and kicked it and nothing happend. I tryed and tryed again and again. I check all my connections and it had gas. The spark plugs are good. Before i put this on it started in one kick yesterday. Anyone got any suggestions?
go here > TORS and make sure you disconnected the right things. Like suggested before make sure slides are moving correctly. Also are you getting gas? Check to see you are getting gas. Check your plugs with the new twist throttle did ya just flood it?
Quick fix..next to the coil...where the plug wires come from..there is the TOR's box. unplug it. if it stars that's it. cap of the conector and throw away that box. it's garbage. the tors is a 3 pin plug.
On the stock thumb throttle thee is a contct switch..that goes to the tors system. I assume the quad was running before you installed the twist throttle. It might be flooded. You will get spark to the plugs with a fualty tors but it won't stay on. I one time spent a half hour pissed off trying to start my Shee before I realised my tether was unplugged. Let's not forget about all the 100 or so times I forgot to turn the fuel on and halfway around the track my quad would die. It's those simple things that cause the biggest headaces.
I was stuck at the track last weekend because my Banshee threw a hissy fit and decided not to start after she was running SO good. an hour later after I was good and pissed off I decided to try one more time and she started like a champ in the first kick. It pissed me off.
