Guys, I have the top end off of my 89 Banshee for my first rebuild (I am sure its not the first for the bike) and everything is lookin good. I do have a crank question though. Per my Clymers manual it says you can have up to 2mm side to side movement at the small end of the rod. The big end movement on the crank is within spec as checked with a feeler gauge but I am little leary of this side to side wiggle. I think I am within spec as best I can measure without a dial indicator. Is this normal how concerned should I be, what other checks can I do from the top of the case?
Thanks in advance for the feedback.
