'85 Rz350 Cases, Side Covers, Etc.
BenBB
I need to try and sell this stuff to help pay for my crank work, let me know if anyone is interested in any or all of it:
'85 RZ350 Top & bottom cases-BARE case set with studs, dowels, and shift rail plugs. Factory paint/powdercoat has been bead blasted, cases have been thoroughly cleaned and all gaskets/sealant removed. Very minor chain damage to upper case, small hole approx 1" x 0.5" that does not extend into gearbox, cosmetic only. Rear motor mount appears to have been narrowed slightly, not real sure what the deal is there but there are no holes into the gearbox. Includes factory hardware (with the wiring harness guide things, clutch cable retainer, etc.), water pump neck, clutch arm, neutral indicator plate, the little plate behind the clutch, countershaft spacer and nut (for front sprocket), tranny drain plug, and tachometer internal assembly (shaft, 3 gears, retainer, cap).
'85 RZ350 Clutch cover-has been bead blasted & cleaned. Only damage I can see is a small indentation just below the round cover, and a scratch below the kickstarter seal boss. Includes factory water pump shaft & impeller, seal, bearing, inner cover, oil pump blockoff plate, round center cover, water pump outer cover (appears to be Banshee and not RZ), and all original hardware.
'85 RZ350 Stator cover-factory plastic cover, includes rubber piece (not gasket) and a few bolts, missing a couple mounting bolts.
'85 RZ350 Rubber intakes with hardware.
'85 RZ350 Reed cages with reeds and stops (all stock).
'85 RZ350(?) Stock Mikuni 26mm carbs-not 100% sure if these were factory on the RZ or not as there is not a linkage between the carbs; similar to a Banshee with TORS removal kit but the bowls have inputs for the oil injection. In comparison to stock carbs the bowls are bigger, and oddly enough the slides don't have a black coating. I didn't disassemble or clean these at all.
'85 RZ350 Shift shaft with chrome shift lever-shaft in perfect condition, lever is stock length and looks decent. Comes with the shift star roller, arm, spring & bolt.
'85 RZ350 kickstarter internal gear assembly with driven gear-perfect shape.
Janssen Racing boost bottle-nice 'n shiny.
Here's a pic of everything, I'd like to get $200 including freight to anywhere in the continental US. If you're after something specific let me know (PM or email) ASAP, as I'm going to put it on ebay in separate auctions if nobody here wants it...
Links to more pics:
http://www.dfn.com/benkaren/rzparts2.jpg
http://www.dfn.com/benkaren/rzparts3.jpg
http://www.dfn.com/benkaren/rzparts4.jpg
http://www.dfn.com/benkaren/rzparts5.jpg
$200 shipped, everything but the carbs is spotless and ready for assembly (or you could polish, paint or powdercoat the cases and clutch cover). Goes on ebay the week of February 9th...
Rzcolobanshee-thanks, that's what I was thinkin'.
Shortys racing-I was hoping I could get $125 for the cases, if you're interested please let me know and make an offer if you think that's too much (that $125 would include freight via UPS Ground).
