pro line Posted January 30, 2004 Report Posted January 30, 2004 My buddy's shee isn't running right when he fires it up one pipe gets hot and the other is cold. He's got good compression in both cylanders and good spark. He has tried a different stator and cdi. Any input would be helpful. Quote
cb67rs1 Posted January 30, 2004 Report Posted January 30, 2004 clean the jets in the carb, sound like its not getting any gas. Quote
frocashmoney24 Posted January 30, 2004 Report Posted January 30, 2004 yea one of the sides isent running so you have to look whats on the one side, a piston reeds, carb... Quote
Demon350 Posted January 30, 2004 Report Posted January 30, 2004 my shee did the exact same, ended up being air screws, check urs might help Quote
Justintoxicated Posted January 30, 2004 Report Posted January 30, 2004 yea, clean out the pilot and main jet and see if it goes away. One side of mine always seems a little warmer than the other, and I have the carbs synced and jets cleaned...its a mystery I guess. Quote
banshee0044 Posted January 31, 2004 Report Posted January 31, 2004 clean the carbs and make shure they are even...maybe take out your airfilter with the bitke not running and mess with the throttle...looking at the carbs.. Quote
Wallrat Posted January 31, 2004 Report Posted January 31, 2004 Mine did that and it turned out that they were way outta sync. Quote
screamingtwin Posted February 1, 2004 Report Posted February 1, 2004 CHANGE the spark plugs. even tho you got spark change them any way. Quote
