hey
which would be better for mx use 33 or 35mm?
does it releave thumb pump rather than the two twin stockers?
is it worth the $450?
please if u have the 2 in to 1 can u tell me how u like it and is it easy to jet?
thanx for your time
I have a C.V. 33mm system, but I've only got to ride on it one day , and I had ton's of bottom end, as far as the 33mm and the 35mm i think 33mm is better with mild bolt on's, and the 35mm is better with a ported motor, and as far as jetting if you want easy jetting get a clamp on filter with it instead of the air box adapter be cause its really more of a pain with the airbox adapter then with the stock carbs, just my $.02
ive got it the cv with the 35, but i agree with ruff rida the 33 is good for bolt ons, its a hall of alot easier to push the throttle with the single carb over the two, gives you alot of bottom end and quick snap of throttle responce, easy as hell to jet, well worth every penny of the 450
