well awhile ago my banshee stopped shifting into gears one at a time, and now im down to one gear, so i ripped the engine out bought some gear forks because i figure one may be broke, but since i have it apart, is there anything else i need to check to make sure its not that before i put it all back togetehr
Check to make sure all the free spinning gears will actually spin and that none of the gears are discolored or blued....check for any chipping or cracking of the gears or shafts....
Check all the little pins on the shift star too.I have seen seen those get worn down enough were the shift shaft would slip off instead off rolling it into gear.
Hey I had the same problem, I could only shift into first and netural. I tore the engine down and found out lastnight that one of the gears would not slide into place. I pulled the gears off till i got to the bad one and found out the shaft it slides on a 2 little marks which made it get caught. I pulled that gear off and sanded everything back down and now all gears are working.
