adam46706 Posted January 13, 2004 Report Posted January 13, 2004 went i bought my quad it had a set of fmf fattys on it. awhile after i bought it they started to leak where the pipe meats the head so i went out and bought new o-rings and springs put them on and cant get them to stop leaking can someone help me out thanks Quote
boonman Posted January 13, 2004 Report Posted January 13, 2004 Holy good God batman. You aren't supposed to be connecting the pipes to the head!!!! man, that's the problem right there..... Quote
got1banshee Posted January 13, 2004 Report Posted January 13, 2004 Holy good God batman. You aren't supposed to be connecting the pipes to the head!!!! man, that's the problem right there..... hahahahaha Damn Boonmans in a hell of a good mood today haha Quote
blk02banshee Posted January 13, 2004 Report Posted January 13, 2004 is the pipe going on straight? if it's a little crooked, it can leak. I bought pro circuits used and had to tweak them slightly to make them fit properly. Never leaked. Quote
NYUK Posted January 13, 2004 Report Posted January 13, 2004 rearange the pipes so they mate up flush with the exhaust port of the jugs. if your pipe springs aren`t holding them tight to the cylinder cut the springs a little shorter and bend the end so it tightens up the pipe to the cylinder.i double my pipe springs up. Quote
2004LEBanshee Posted January 14, 2004 Report Posted January 14, 2004 When I installed my pipes I used a bunch of high temp silicone and they don't leak yet not sure if it helped but might be worth a shot. Quote
Yamaha350T Posted January 14, 2004 Report Posted January 14, 2004 Ya definitely put some high temp silicone on em. I used that on my pipes too and they havent leaked yet at all. Just clean the blackness out of where the pipe meets the flange,,and clean the flange, then just load up the flange and the pipe. You can also put it in your pipe clamps, especially if you have the "no leaks", because they definitely do leak as soon as the o rings wear out. Quote
spoin39 Posted January 15, 2004 Report Posted January 15, 2004 I would check the exhaust flange to be sure there isn't a nick or scrape on it to prevent from leaking. Quote
