cmyyard19 Posted January 9, 2004 Report Posted January 9, 2004 I need a 10mm carrier bolt and nut. I you have one or know where I can get one that would be great. Quote
flea49 Posted January 9, 2004 Report Posted January 9, 2004 The best is buy a new one,Go to albaaction.com and click on part finder. Quote
rebelbanshee2 Posted January 10, 2004 Report Posted January 10, 2004 you want the big bolt that holds the carrier to the swing arm? I have the top and bottom one with the washers and nuts. PM if you are interested. Quote
Blue Duece Posted January 10, 2004 Report Posted January 10, 2004 arnt the carrier bolts 17's with a 14 and 17mm nut......the skids a 12mm?.the only 10 back there is the outside chain adjust........... Quote
cmyyard19 Posted January 10, 2004 Author Report Posted January 10, 2004 The bolt I need is the smaller one that holds on the carrier. Quote
banshee962000 Posted January 10, 2004 Report Posted January 10, 2004 i responded to you pm if your interested in mine i need to know soon so i can have it sent out if not good luck Quote
