jack vo Posted July 8, 2025 Report Posted July 8, 2025 (edited) Was recently given an rd400 engine by a friend. He junked the motorcycle chassis cuz it was crashed. He doesn't want anything to do with motorcycles anymore. I'm thinking about getting a banshee chassis and putting this engine in it. The engine has been ported polished in the head has been milled. It was modified with v Force reeds and has a modern ignition system. From what he told me it took really well to race gas. Is it worth putting in a Banshee chassis or should I be looking for a different chassis to put it in. Thank you Edited July 8, 2025 by jack vo Quote
kawa110 Posted July 8, 2025 Report Posted July 8, 2025 The trans will setup for street speeds. Banshee chassis don’t have best suspension geometry Sent from my iPhone using Tapatalk Quote
jack vo Posted July 8, 2025 Author Report Posted July 8, 2025 1 hour ago, kawa110 said: The trans will setup for street speeds. Banshee chassis don’t have best suspension geometry Sent from my iPhone using Tapatalk That's true Quote
kawa110 Posted July 9, 2025 Report Posted July 9, 2025 Get a wiring harness and elect components with the engine, exhaust pipes? Put it in a lightweight street bike chassis.Sent from my iPhone using Tapatalk Quote
jack vo Posted July 9, 2025 Author Report Posted July 9, 2025 I have everything that goes with it. Quote
kawa110 Posted July 9, 2025 Report Posted July 9, 2025 I would just find a rd400 or 350 that is blown or a basket case and build a street bike so u can utilize all the components opposed to modifying exhaust, engine mounts, potentially wiring harness, control cables, adding a cooling system, ect…If you can weld yfz hybrids are common. Member tfaith here on the website can build you a custom chassis with correct geometry. Sent from my iPhone using Tapatalk Quote
jack vo Posted July 10, 2025 Author Report Posted July 10, 2025 17 hours ago, kawa110 said: I would just find a rd400 or 350 that is blown or a basket case and build a street bike so u can utilize all the components opposed to modifying exhaust, engine mounts, potentially wiring harness, control cables, adding a cooling system, ect… If you can weld yfz hybrids are common. Member tfaith here on the website can build you a custom chassis with correct geometry. Sent from my iPhone using Tapatalk Thank you Quote
