Spike25 Posted October 1, 2024 Report Posted October 1, 2024 Does the 33mm retain bottom end power and use a lot more fuel than the 28mm or are they just about the same? Quote
ClaudeMachining Posted October 1, 2024 Report Posted October 1, 2024 Does the 33mm retain bottom end power and use a lot more fuel than the 28mm or are they just about the same? Smaller =more torque, easier to set.Envoyé de mon SM-S908W en utilisant Tapatalk Quote
locogato11283 Posted October 5, 2024 Report Posted October 5, 2024 What motor are you putting these on? If it's not a 4mm+, then 28mm will be the better option. Quote
Spike25 Posted October 9, 2024 Author Report Posted October 9, 2024 I have a 4 mil,421 driveline assassin low port setup with stock carbs. Thinking if it makes sense to port them for a little more power, which ever route I go, I absolutely need to keep my bottom end power, love it when the bike is really snappy. I really appreciate the input, which one will keep it snappy? Especially if ported or left as is? Quote
ClaudeMachining Posted October 9, 2024 Report Posted October 9, 2024 I have a 4 mil,421 driveline assassin low port setup with stock carbs. Thinking if it makes sense to port them for a little more power, which ever route I go, I absolutely need to keep my bottom end power, love it when the bike is really snappy. I really appreciate the input, which one will keep it snappy? Especially if ported or left as is?My 421 was an Assassin LP with 33mm.Ask for a nice "clean port", match you cases, good reed valves and go with slp pipes and 28mm.That will be a good "trail friendly" engine.Dunno if 33mm would be a big difference for trail, but it will drink more fuel for sure.Envoyé de mon SM-S908W en utilisant Tapatalk Quote
Spike25 Posted October 10, 2024 Author Report Posted October 10, 2024 Gotcha, thank you for the information 👍 Quote
