SheAus Posted June 24, 2024 Report Posted June 24, 2024 Has anyone used a stroked bottom end with long rods, and paired them with standard pistons and cylinders and used a spacer plate to allow for the extra stroke? I’ve just bought a banshee that had a 421 kit in it. But it had stock cylinders bored out with a spacer plate to allow for the extra stroke. The cylinder exhaust port has cracked. So that eliminates using those cylinders. i also got a seized motor in the deal, what’s my best option? The stroked bottom end is still in the bike and in good condition Quote
gusto Posted June 24, 2024 Report Posted June 24, 2024 Buy used stock cylinders and have them ported for the crank and your domes cut for the crank. No space required. youll need stroker pistons stock cylinders cut domes for stroke aftermarket head. have your crank inspected and send to a banshee builder there are a bunch. Quote
locogato11283 Posted June 24, 2024 Report Posted June 24, 2024 Throw that spacer away. You don't want that headache. Where are you located? Might be a BansheeHQ Sponsor nearby you can take it to. Quote
