Banshee_ Posted April 14, 2023 Report Share Posted April 14, 2023 Hi, i need some help with my jetting! my setup is toomey T5 oem carbs tors deleted vforce 4 cylinders have a little work just cleaned up the rough sides raised exhaust a little not much bored 65,25 Toomey uni filter stock airbox with the lit cut inside no snorkle mains jets 280 pilots 27,5 Toomey needles 4 groove from top At sealevel i was wondering if my jetting is in the right direction or is it off what is seems to be i always need my choke to start the bike without it takes a few kicks with the choke it is like 1 or 2 kicks before i put the the toomey needles in it took 1 kick without choke with stock needles but that was when i just rebuild the bike so i dont know what the problem is we dont drive alot here in the netherlands due to wether hope you guys can help me tho!! Many thanks Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted April 17, 2023 Report Share Posted April 17, 2023 That should be really close. You might try turning in the air screws a little. Also, if it sits a lot and depending on the fuel quality, the pilot circuit might just need cleaned. Quote Link to comment Share on other sites More sharing options...
