locogato11283 Posted January 28, 2023 Report Posted January 28, 2023 FOR SALE: Redline Racing 24DM. 78mm bore. Chariot stator cover. Mattoon Machine cases and clutch cover. Shift fork window. 8 plate clutch with billet basket. N down 2-5 with billet second gear. 39mm PWK bored to 40.5mm and set up for a pump. UPP intakes. Air filters. LED pipes. Welded on near the cylinder a couple times but barely noticeable when in the chassis. All rubber mounted. I talked to Cam at Redline earlier. Cover to cover with pipes and carbs now is close to $18,000 and a 6+ month wait. This is ready to put in a bike and run. Pistons are in good shape. Cylinders are in good shape. Domes are good. I also have a stock cylinder chassis setup that this could go in for the right money. $13,000 picked up. Quote
registered user Posted February 4, 2023 Report Posted February 4, 2023 he said hes hangin it up. no more tuckin in Quote
