onefastazzbanshee Posted November 17, 2022 Report Share Posted November 17, 2022 05 Banshee with t5's, vforce 4 reeds, and k&n pods currently running 280 mains 25 pilots needle 4th clip. Was thinking of going up a size on each jet to 290 mains 27.5 pilots for winter, do you think it’s worth the change currently starts and runs great just thinking it would run better with alittle more fuel with my mods? or do think it should be fine where it’s at and just leave it? Quote Link to comment Share on other sites More sharing options...
onefastazzbanshee Posted November 17, 2022 Author Report Share Posted November 17, 2022 I’m in Florida, bike runs strong just thinking it could be alittle lean… Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 18, 2022 Report Share Posted November 18, 2022 Your pilot is definitely lean. Go to 27.5. As far as the main is concerned, you really need to do a WOT plug test. 280 should be close though. Quote Link to comment Share on other sites More sharing options...
onefastazzbanshee Posted November 21, 2022 Author Report Share Posted November 21, 2022 On 11/18/2022 at 2:24 PM, locogato11283 said: Your pilot is definitely lean. Go to 27.5. As far as the main is concerned, you really need to do a WOT plug test. 280 should be close though. Yeah, right now I’m at 1.5 turns out on the air screws starts first kick with choke out, then it doesn’t need choke to start after, I did have to raise the idle about a half turn after vforce 4 reeds to get it to idle right. How many turns out on air screw with the 27.5? Quote Link to comment Share on other sites More sharing options...
