onefastazzbanshee
Everything posted by onefastazzbanshee
  1. Sounds good looks like I’m going to have to run the hoses, that way everything stays clean and drips down to the bottom instead of on the engine.
  2. Was definitely thinking of doing this only thing is theres 2 on each carb… and adjusting floats to leak less would be good if possible right now they’re adjusted to 21mm from base of carb to float, I would have to adjust them to 22-23mm to leak less is this correct?
  3. How can I make these carbs leak less gas they leak out of the hoses on sides of carbs onto engine and out the ones that go to bottom of bike, I adjusted floats because it was leaking even while it was off with gas on. Now that’s fixed only thing is when I do wheelies it still leaks a lot, I know this can be normal, just wondering if there’s a way to make it leak less? Bike is an 05 with t5’s, vforce4 reeds, and k&n pods, stock carbs.
  4. Yeah, right now I’m at 1.5 turns out on the air screws starts first kick with choke out, then it doesn’t need choke to start after, I did have to raise the idle about a half turn after vforce 4 reeds to get it to idle right. How many turns out on air screw with the 27.5?
  5. I’m in Florida, bike runs strong just thinking it could be alittle lean…
  6. 05 Banshee with t5's, vforce 4 reeds, and k&n pods currently running 280 mains 25 pilots needle 4th clip. Was thinking of going up a size on each jet to 290 mains 27.5 pilots for winter, do you think it’s worth the change currently starts and runs great just thinking it would run better with alittle more fuel with my mods? or do think it should be fine where it’s at and just leave it?
  7. Ok sounds good yeah I think I might run it the way it is and if I notice it sluggish on bottom end I'll go up on pilot
  8. I have a 2005 Banshee with T5 pipes and pods and just bought v-force 4 reeds for it (haven't installed yet) and was wondering if the reeds will need different jetting? right now it has 280 mains and stock pilots, I have 27.5 pilots coming in, should I run the reeds with my current jetting or put the 27.5 pilots in while doing the install? Thanks
