Hey guys, here is what I did so I don't burn my outerwares and I don't have to worry about my filter being centered perfect. See the hose I ran on my stinger tubes? It is high temp Silicon hose. Works pretty good.
pretty good idea,
i did that with the braided high temp hose to keep it from burning my fullbores anymore :angry: it was kinda shatty i just put my fullbores on and my t5 stinger tubes shifted and melted a big ol dent into my back left side...cant see it when im sitting on the bike but still
i might need to try that since i switch to a 2 into 1 from my k&n's
mike
Hmmm :huh: I've never had any problems with melting my outerwear with my 2:1...I just loosened the clamp holding the filter, rotated the filter to where there is an equal distance between the pipes & the filter. I'm still running the same outerwear that came with the filter. ;)
I never have either, but some have.
Also, I don't have to worry about rotating mine, just get it close and who cares.
i run the t5's and i melted my 1st outerwear,yes i rotated the filter to the center,but i just use a rubber band around the center of the filter to hold the outerwear back from the pipes.never had a problem sence.
Man (some of) you guys are cranking on me like I did something bad here. I just posted something that works for me that might be able to help others.
This is the Tips & Tricks Forum.
If you don't like it, don't do it, but also don't reply. :angry:
I ran the 2:1 filter with my T5's a melted it even though I had the filter rotated to be in the center. Then I went with Trinity pipes and they are all up on the filter. So great tip. If I don't switch to a 2:1 intake, I'm gonna do what you did.
I'm sure it's possible...I just gave MHO & what I did and it's worked for me, with PC pipes anyhow. :huh:;)
Anyone ever tried that flame retardant spray,....like that crap you spray on X-mas trees & fabrics to keep them from burning up? Think it would work?? Wonder if it'd clog the outerwear?...if it worked that'd be a god send for those running clamp-ons & some with the 2:1. :)
Oh yeah,...and do the waterproof outerwears hold up to heat better?
