Dune trip. Jetting advice
Hey guys, I have an 03 shee and it has FMF fatty’s with turbine core 2 silencers, uni filter, boyesene power reeds, stock air box, +4 timing plate. Stock motor.
It’s been so long since I rejetted this thing cause most of my riding is at 3500ft. I can’t remember what I have in the carbs for jets. I believe I have 27.5 pilots, needle is middle position but can’t remember the mains.
In a couple weeks I am making my first trip to the dunes in Oregon.
What jetting should I set this banshee to?
I will be running paddle tires as well.
I’m planning on pulling the carbs tomorrow and rejetting
Any help is appreciated.
Thanks !!
when are you going? I am from Abbotsford I will be there from the 29th of april for 4 days.
for those mods probably a 310 main or a 320 main will do. I have a banshee with fmf pipes vforce reeds and a k&N its running 310 mains. I run the same jetting as here but you sound like your up north.
Thanks for the reply. I live in the lower mainland but the banshee is used up north at the family cabin.
Ill be in the dunes after your trip is done.
I did some research and called a couple places about jetting. Since I’m running stock airbox with lid on and a uni filter, I was told to run 280’s.
They told me if I was running a K&N and no lid, run a 320.
Does that make sense ????
Thx Again.
  • 2 weeks later...
