4mil short rod 513 66mm pistons stock cylinders 4mil 19cc dimes squish is 44 thousandths compression was 205 each cylinder . Now the fun Distorted piston after plug center came out BR7ES .30 gap . 35mm air strikers 160 main 48 pilots center on needle . C16 fuel 40-1 Elevation between 2000ft an 3000ft different 1/8 miles . So I need help new piston an dome on the way . An ported to 196 on a deg wheel  maybe 10 passes .
Edited by Fordfamily63
Forgot run time
sounds like it was detonating if the sparkplug came apart. why are you running a br7? should be running a br8 or even a 9 on that setup. any detonation on the other piston?
  • 3 weeks later...
No on voitos  an in Tennessee it was still cold an had  jets right so I thought now it’s 100 over 1/8th start an stop that’s it what is max on compression I can go I raised base gasket up 4 thousandths have not set cylinders on yet
An skeeter had a stock crank 80 over 170 on pump gas . 1/8th mile running 7.60s so I have a problem with fuel an jets not motor building.
