caleb90 Posted May 2, 2021 Report Posted May 2, 2021 first start and run since the build. ran a heat cycle no air filters while getting carbs tuned up. put air box on ect and ran another heat cycle. no load on motor just high idle and throttle wacks.sucker is running fat very fat, 350 mains 30 pilots. did a quick compression test on hot motor, 115 ,120 psi .. 4mil long rod 23cc domes squish at .052 1400ft elevation. n im about to ditch the air box pita! Quote
375hp banshees Posted May 2, 2021 Report Posted May 2, 2021 Don't know about at 1400, but that seems fat on both. did you plan on ditching the Box anyway? you didn't over oil your air filter(s) did you? Quote
caleb90 Posted May 2, 2021 Author Report Posted May 2, 2021 56 minutes ago, 375hp banshees said: Don't know about at 1400, but that seems fat on both. did you plan on ditching the Box anyway? you didn't over oil your air filter(s) did you? it was fat with bare carbs.. stock carbs, 4mil long rod, fast dune port, fmf pipes, +4 timing. i intended on keeping the stock box with pro flow set up, but after taking it on/off 3 times today im sick of it. Quote
caleb90 Posted May 2, 2021 Author Report Posted May 2, 2021 compression seems low to me, but it is a fresh bore. maybe pick up 10psi? idk Quote
375hp banshees Posted May 2, 2021 Report Posted May 2, 2021 Yeah, didn't catch that part, gauge has alot to do with that tho. Pods are nice to tune with , but once you tune it, you shouldn't need to do much & a box gives you more riding style protection. Quote
caleb90 Posted May 2, 2021 Author Report Posted May 2, 2021 autozone brand guage. has valve on adaptor and just below the guage its self Quote
caleb90 Posted May 2, 2021 Author Report Posted May 2, 2021 did a third heat cycle. up to 130psi now Quote
