so i wound up with a wiseco 65mm rebuild kit and a set of niche jugs and a yamaha head, in a trade for the oem carbs i had gotten. pulled my jugs off and hardly a scratch, pretty sure its the stock bore i still need to measure. not wanting to punch my cylinders out .40 if not needed. i thought i will just get the niche cylinders punched out. good god there terrible looking, rough casting in every port none of the ports are chamfered. before i even attempt to take them to the shop to get bored im going to have to dremel every thing down.. hoping i can get by with my stock bore with a fresh hone and rings
Sent from my SM-G920V using Tapatalk
stockers i pulled off last night, assuming all the brown on the sleeve is from blowbye and dirt.. it wont come off717c69aa1168d2143b8f997dbf890d96.jpg
