Tarrenitup82 Posted February 23, 2020 Author Report Posted February 23, 2020 So you think it’s the clutch cover/ gasket? Quote
Tarrenitup82 Posted February 23, 2020 Author Report Posted February 23, 2020 I have an o ring kit so I put a new o rinf on the transfer tube and then out about a liter of transmission fluid in it. It’s no coming from the vent hoses when I let it just run and reved a few times but is still coming from the block where the transfer tube comes out. So you think clutch gasket and new cover because of the gauge in mine? That’s all I can think of beside a crank seal Quote
375hp banshees Posted February 23, 2020 Report Posted February 23, 2020 Yes, sorry about the confusion, i thought the tube issue you were having was coolant @ 1stSent from my SM-A505U using Tapatalk Quote
Tarrenitup82 Posted February 23, 2020 Author Report Posted February 23, 2020 You think a new clutch cover and gasket are the way to go? Quote
375hp banshees Posted February 23, 2020 Report Posted February 23, 2020 Or used, There's a lot on bhq swap shop Facebook or redo banshee's is a site Sponsor Sent from my SM-A505U using Tapatalk Quote
Tarrenitup82 Posted February 23, 2020 Author Report Posted February 23, 2020 That’s what I meant sorry. A *different cover? Quote
Tarrenitup82 Posted February 23, 2020 Author Report Posted February 23, 2020 Also when I blow into the one of the vent tubes and plug the other it starts to leak oil from the transfer tube spot I was talking about. Leaks in between the tube and block or case so I do believe it would be the cover. Opinions Quote
375hp banshees Posted February 23, 2020 Report Posted February 23, 2020 Yes by doing that there's no venting going on and oils going to go out any leak. if your doing it with it off, that area must have trapped oil, from before. I wouldnt think there would be oil there unless slung up there while running, by getting by gouge. With That being Said, make sure you clean that cavity between the tube and cases so when ur done there's no Residual and you think it's not fixed Sent from my SM-A505U using Tapatalk Quote
kawa110 Posted February 23, 2020 Report Posted February 23, 2020 I got a pretty rough shape stock cover, that Does NOT leak. 20$ PayPal gifted to me and I’ll send it your way on Monday. I can get you pics late tonight or tommarow. Sent from my iPhone using Tapatalk Quote
Tarrenitup82 Posted February 25, 2020 Author Report Posted February 25, 2020 My buddy let me test his cover out and it leaked out the rear vent for a couple minutes then suddenly stopped. After wards I tried to make it do it again and it wouldn’t. Even did a couple wheelies and 6 gear wot. Nothing so I hope it’s fixed. I got myself a new cover and new gasket Quote
375hp banshees Posted February 25, 2020 Report Posted February 25, 2020 Again, how do you know it was that (rear) vent?Sent from my SM-A505U using Tapatalk Quote
Tarrenitup82 Posted February 26, 2020 Author Report Posted February 26, 2020 Because he has the one on the cover blocked off. And I ran the rear one by the swing arm Quote
375hp banshees Posted February 26, 2020 Report Posted February 26, 2020 Oh, on the borrowed cover...gotcha Quote
