TheBull Posted January 25, 2020 Report Posted January 25, 2020 I have a 97 banshee. It will not rev up all the way with or without a load. I have changed plugs, I had carbs cleaned, I replaced the coil, I installed the new vforce 4 reeds and still having the issue it cranks and idles fine. But when you get into the powerband it just breaks down. I have played around with air/fuel mixture no real improvement I don't know much about 2 strokes so any thoughts or suggestions would be appreciated Quote
375hp banshees Posted January 25, 2020 Report Posted January 25, 2020 Cut back your plug wire endsSent from my SM-A505U using Tapatalk Quote
gusto Posted January 25, 2020 Report Posted January 25, 2020 Try swapping out the cdi new reeds may require more jetting Quote
TheBull Posted January 26, 2020 Author Report Posted January 26, 2020 I did cut back the plug wires so that's not it. I have not checked the cdi or stater yet Quote
TheBull Posted January 26, 2020 Author Report Posted January 26, 2020 Great scott Marty! But where am I going to get 1.21 gigawatts? 1 1 Quote
Pinkylee Posted January 27, 2020 Report Posted January 27, 2020 Have you had your stator cover off yet ? Is it sealed well ? I ask because when I took apart the one I am currently building. It was just FULL of dirt and rusted. Pick up coil and stator was rusted and needed cleaned !!!Sent from my LG-H700 using Tapatalk Quote
TheBull Posted January 27, 2020 Author Report Posted January 27, 2020 I have not checked that yet but I will try that today. Thank you Quote
