Ken O’Connor racing sells the SportPort templates for 110$
i would give it a go on your own with some trashed cylinders first
Thanks for the info,found his website, quite informative.
Sent from my ONEPLUS A3000 using Tapatalk
What is the difference between stage II fast trail and stage III super stock ?
  • 2 weeks later...
Hi, new here.
Interested in porting, I’ve done a fair amount in other 2 strokes. Curious why you guys don’t use timing numbers?
  • Like 1
Hi, new here.
Dont need to. Banshees are already fast as fuck. Just get in there and open shit up
Sent from my SM-G970U using Tapatalk
Hi, new here.
Don't know much about porting so templates sound like good starting point. What do you mean timing numbers, duration and time when and for how long what port is opening?
Sent from my VOG-L29 using Tapatalk
Yeah pretty much, I use the port opening numbers. I can measure in durations for exhaust and intake but transfer durations elude me.
  • Like 1
Do you have a link on how it's done?
I do not, I’ve only ported small single cylinder 2 strokes, chainsaws. But, installing a timing wheel should be the same.
mount the wheel on the crank, set the wheel at tdc with corresponding piston at tdc. Then read port openings. Exhaust roof, transfer roofs, intake floor.
  • Like 1
