d3ac0n Posted November 20, 2019 Report Posted November 20, 2019 Im a little confused, so i have 2 keihin pwk 35mm carbs on my shee, both have an air mixture screw. Is the proper way to adjust the airscrew on ONE carb at a time, finding the highest idle then continuing on to the second carb, or am i supposed to make identical adjustments to the air mixture on both carbs at the SAME time? Quote
Ayesully810 Posted November 20, 2019 Report Posted November 20, 2019 (edited) same time. if you do a half turn on left one, do a half turn on the right one. Give it a few seconds to sync then blip the throttle. Once the idle starts hanging a bit, youve found your highest point. Ill usually turn the af screw in a half turn at that point and the idle hang should go away. If you end at at only a Half turn out on each carb, a size bigger should put you at the perfect pilot jet size. Edited November 20, 2019 by Ayesully810 Quote
d3ac0n Posted November 25, 2019 Author Report Posted November 25, 2019 On 11/20/2019 at 3:09 PM, Ayesully810 said: same time. if you do a half turn on left one, do a half turn on the right one. Give it a few seconds to sync then blip the throttle. Once the idle starts hanging a bit, youve found your highest point. Ill usually turn the af screw in a half turn at that point and the idle hang should go away. If you end at at only a Half turn out on each carb, a size bigger should put you at the perfect pilot jet size. Thanks bro, although im not quite sure what a hanging throttle sounds like, or does, could you please explain it a bit? Thanks Quote
Ayesully810 Posted November 26, 2019 Report Posted November 26, 2019 when you rev it and the rpms hang instead of idle down Quote
