doug Posted July 9, 2019 Report Posted July 9, 2019 Hi Gents, I'm trying to install a new set of rear brake pads. Typically a dead simple job. I've opened the caliper using a c-clamp so that only about 1mm is out, as shown in the attached photo. Despite this, there is not enough room between the new pads for the disc. I checked the brake pads and they are the correct ones. Any ideas that the hell is going wrong? I must be losing my mind. Thanks. Quote
Canadianshee Posted July 9, 2019 Report Posted July 9, 2019 Are you running oem pads? Some of the aftermarket pads are a tad thicker. Sent from my LG-H873 using Tapatalk Quote
kawa110 Posted July 9, 2019 Report Posted July 9, 2019 Piston in far enough? Cap off the resivior? Disk warped? Sent from my iPhone using Tapatalk Quote
doug Posted July 10, 2019 Author Report Posted July 10, 2019 Aftermarket pads. Good thought. The piston is in as far as I can get it. (out approx. 1mm as shown in photo) Yes, cap off both reservoirs. Disk does not appear warped. Thanks guys! 1 Quote
gusto Posted July 10, 2019 Report Posted July 10, 2019 I’ve had to drain the lines to get the piston to move in more than re bleed Quote
bansheesandrider Posted July 10, 2019 Report Posted July 10, 2019 Does it still have the park brake setup on it? If it does, back out the PB screw adjuster, then readjust the park brake after you have bled it . 2 1 Quote
doug Posted July 10, 2019 Author Report Posted July 10, 2019 gusto - can you tell from the photo if it should be in further? bansheeandrider - did this already, thanks. Thank you for the help. Quote
gusto Posted July 11, 2019 Report Posted July 11, 2019 Hard for me to tell. I just went through this process a few months back and when I had no pressure in the lines I moved the piston in farther. I’d hate to have you re bleed for nothing though if it does t work. I rented the vacuum tool and it made all the difference Quote
doug Posted July 15, 2019 Author Report Posted July 15, 2019 I went back out to the garage and removed the parking brake and then the I was able to compress the piston all the way in. Shown in red in the pic. The outside portion goes in as well. Once I did this, the pads fit fine and I was riding. Thanks for the help. Does anyone know what the "button" and cap inside the red are for? Looks like mine was glued at one point, but now it will just fall out when the pads are out. Quote
ginger Posted July 15, 2019 Report Posted July 15, 2019 are you talking about the piston? if you dont have anything to limit it, and you keep pumping the brakes it will fall out. Quote
doug Posted July 15, 2019 Author Report Posted July 15, 2019 On the top of the piston there is something that looks like a thick quarter. On top of that is a cap. In my case, both came out when I took the pads off. I put them back on, so it's not that important, I was just curious. I've looked at the microfiche and don't see them. Quote
AKheathen Posted August 21, 2019 Report Posted August 21, 2019 same thing for a lot of 90s imports and other caliper integrated park brakes, so keep that in mind if you run into a brake job ans see dowell holes or slots in the piston. 1 Quote
