Banshee802 Posted June 25, 2019 Author Report Posted June 25, 2019 where are you losing air from? IntakesSent from my iPhone using Tapatalk Quote
ClaudeMachining Posted June 25, 2019 Report Posted June 25, 2019 It's all good I use a leak test to look for BIG leak, not small stuff. Envoyé de mon SM-G965W en utilisant Tapatalk Quote
Banshee802 Posted June 25, 2019 Author Report Posted June 25, 2019 43 minutes ago, ClaudeMachining said: It's all good I use a leak test to look for BIG leak, not small stuff. Envoyé de mon SM-G965W en utilisant Tapatalk So you think my new top end will be fine if I run it like this? Quote
ClaudeMachining Posted June 25, 2019 Report Posted June 25, 2019 So you think my new top end will be fine if I run it like this?What is your setup, intakes wise???Envoyé de mon SM-G965W en utilisant Tapatalk Quote
Banshee802 Posted June 25, 2019 Author Report Posted June 25, 2019 1 minute ago, ClaudeMachining said: What is your setup, intakes wise??? Envoyé de mon SM-G965W en utilisant Tapatalk Vforce delta reeds. Stock oem cylinders. Stock intake boots and carbs Quote
ClaudeMachining Posted June 25, 2019 Report Posted June 25, 2019 Vforce delta reeds. Stock oem cylinders. Stock intake boots and carbsWhere does it leak???? Envoyé de mon SM-G965W en utilisant Tapatalk Quote
Banshee802 Posted June 25, 2019 Author Report Posted June 25, 2019 3 minutes ago, ClaudeMachining said: Where does it leak???? Envoyé de mon SM-G965W en utilisant Tapatalk On the top and bottom of both reed blocks. Not sure if between boot and block or block and cylinder. It also has a ton of little bubbles coming around some of the holes that the mounting bolts go in. I wasn’t shy with gasket maker either. Shit still leaks though 😡 Quote
ClaudeMachining Posted June 25, 2019 Report Posted June 25, 2019 On the top and bottom of both reed blocks. Not sure if between boot and block or block and cylinder. It also has a ton of little bubbles coming around some of the holes that the mounting bolts go in. I wasn’t shy with gasket maker either. Shit still leaks though Clean and redo.The mistake i did was to not wait enough time before testing.How long let you set the gaskett maker??Envoyé de mon SM-G965W en utilisant Tapatalk Quote
Canadianshee Posted June 25, 2019 Report Posted June 25, 2019 Did you put gasket sealer on the bolts does not need much. Sent from my LG-H873 using Tapatalk Quote
Banshee802 Posted June 25, 2019 Author Report Posted June 25, 2019 Clean and redo.The mistake i did was to not wait enough time before testing.How long let you set the gaskett maker??Envoyé de mon SM-G965W en utilisant TapatalkSat for at least 2 days. Put it on and forgot about it. I’ll give it another try, but this will be the 3rd or 4th attempt. After that i might just give it awaySent from my iPhone using Tapatalk Quote
Banshee802 Posted June 25, 2019 Author Report Posted June 25, 2019 Did you put gasket sealer on the bolts does not need much. Sent from my LG-H873 using TapatalkI did NOT put sealer on bolts! Maybe this is my problem. Didn’t think about doing that at all. Also, I took your advice on getting frame powder coated. I love the colorsSent from my iPhone using Tapatalk 2 Quote
Ayesully810 Posted June 25, 2019 Report Posted June 25, 2019 I bet if half the people with healthy running bikes pressure tested their motors they would have little leaks here and there. With that said, use 3 bond on every surface if it bothers you that much. cylinder face, both sides of 1st gasket, on reed block perimeter, and both faces of the last gasket. 1 Quote
Canadianshee Posted June 25, 2019 Report Posted June 25, 2019 I did NOT put sealer on bolts! Maybe this is my problem. Didn’t think about doing that at all. Also, I took your advice on getting frame powder coated. I love the colorsSent from my iPhone using TapatalkWhen you get it done post some pics Sent from my LG-H873 using Tapatalk Quote
Banshee802 Posted June 25, 2019 Author Report Posted June 25, 2019 When you get it done post some pics Sent from my LG-H873 using TapatalkBesides finishing up the intakes I just have to do some shining on the aarms and on my t6s. It won’t be a show piece by any means but I’ll be happy with it for now haha. Here’s how the silver vein came out:Sent from my iPhone using Tapatalk 1 Quote
Canadianshee Posted June 25, 2019 Report Posted June 25, 2019 Turned out nice. It a tough coating Sent from my LG-H873 using Tapatalk Quote
