andrew.s Posted March 4, 2019 Report Posted March 4, 2019 So I went riding this weekend at sandlake in Oregon and when I'm pinning it for more then like 15 seconds the bike just looses all power like I turned the bike off and I have to pull the clutch in rev it a bit then it's fine again. Any reason this could be happening? Quote
Canadianshee Posted March 4, 2019 Report Posted March 4, 2019 What modifications have you done to the bike or was done to the bike, pipes,carbs jetting, pipes, porting Could be a range of things Sent from my LG-H873 using Tapatalk Quote
andrew.s Posted March 4, 2019 Author Report Posted March 4, 2019 5 hours ago, Canadianshee said: What modifications have you done to the bike or was done to the bike, pipes,carbs jetting, pipes, porting Could be a range of things Sent from my LG-H873 using Tapatalk From my knowledge all that was done to it was toomey t5 pipes and a Toomey air filter and porting done by Oregon Motorsports I believe Quote
Canadianshee Posted March 4, 2019 Report Posted March 4, 2019 What do the plugs look like, what jet's are in the carbs. When was the bike last running well, was there a large elevation change where you were riding. Sent from my LG-H873 using Tapatalk Quote
andrew.s Posted March 4, 2019 Author Report Posted March 4, 2019 17 minutes ago, Canadianshee said: What do the plugs look like, what jet's are in the carbs. When was the bike last running well, was there a large elevation change where you were riding. Sent from my LG-H873 using Tapatalk Has brand new plugs, no idea what jets it has, bike didn't do this about 2 rides ago so probably 5 hours of engine time ago and no elevation change sea level everytime. Quote
SKEETER Posted March 4, 2019 Report Posted March 4, 2019 Well, my advice would be to pull carbs off, and get jet sizes, few of us live in orygun and know what that motor will need at sandlake, florence, etc. Quote
n2otoofast4u Posted March 4, 2019 Report Posted March 4, 2019 It's cold as F around here right now. I'd start with jet sizing as Skeet suggested. Quote
andrew.s Posted March 5, 2019 Author Report Posted March 5, 2019 On 3/4/2019 at 1:28 PM, SKEETER said: Well, my advice would be to pull carbs off, and get jet sizes, few of us live in orygun and know what that motor will need at sandlake, florence, etc. I cleaned the carbs today there was literally sand inside the jets so that isn't good.. I'm gonna use air filter oil next time and the jets are 290s idk if I just fixed my problem I won't know till I go riding next but my left carb pours gas out of the over flow when I turn the gas on and I have to turn the gas off then back on again and it's fine not sure what this means Quote
kawa110 Posted March 5, 2019 Report Posted March 5, 2019 Means carbs need more attention. The fuel valve needle and seat may need replaced/or float height set. Quote
mercury65 Posted March 10, 2019 Report Posted March 10, 2019 Let me give you something to look for. I bought mine new from dealer rode it one time then put on the Toomey t5 kit all was good, 4 weekends later the motor locked up. as I pulled it apart I started finding sand within. long story short the stock air filter foam ring rolled up at the bottom as the filter was slid down into the air box that was the last time the stock box was on my shee Quote
Jeffyjeff Posted March 16, 2019 Report Posted March 16, 2019 Try lowering the gap on the spark plug and see if that helps at all Quote
Ayesully810 Posted March 16, 2019 Report Posted March 16, 2019 6 minutes ago, Jeffyjeff said: Try lowering the gap on the spark plug and see if that helps at all good idea, pull the plug, check jetting, had plugs back out at dunes once when it was jetted too lean, started to close the gap even. this was after back to back drag racing at a strip. more fuel cleared it up Quote
