Banshee802 Posted January 7, 2019 Report Posted January 7, 2019 Ok so I’ve read just about every thread on non working headlights that I could find. Still can’t quite figure it out. I’ve tried an eBay stator then bought an oem stator, still nothing. Both ohmed out within spec for all 3 tests. How do I check lighting coil voltage from the stator while the bikes running? Red lead in yellow stator wire and black lead to ground or black to black? Thx Sent from my iPhone using Tapatalk Quote
97Screamer Posted January 7, 2019 Report Posted January 7, 2019 Red to yellow and black to black, meter in AC mode. Should see about 10-50 depending on RPM if I remember correctly. It that checks out you can check voltage out of regulator and make sure its ~12V (I measure at the light sockets but you can check back by the regulator if you want). Quote
97Screamer Posted January 7, 2019 Report Posted January 7, 2019 Everything you need to know is here: 1 Quote
Banshee802 Posted January 7, 2019 Author Report Posted January 7, 2019 K so I tested stator and that gets 15volts at idle and 40v when revved. To check the voltage regulator I unplugged the blue connector put red lead on male blue wire and black lead on ground wire. Didn’t read anything. Did I do this wrong or is my regulator shit?Sent from my iPhone using Tapatalk Quote
Banshee802 Posted January 7, 2019 Author Report Posted January 7, 2019 Nevermind I figured it out lol. Having one of those daysSent from my iPhone using Tapatalk Quote
Banshee802 Posted January 7, 2019 Author Report Posted January 7, 2019 Alright so getting 12volts out of the plug where it goes to the headlight plug in. I took the bulb out and it looks fine and has resistance and continuity going through it. Doesn’t this mean it’s still good? Would the throttle sensor, of tors stuff have anything to do with the grounding to the headlights? That is all unplugged but still on the harnessSent from my iPhone using Tapatalk Quote
97Screamer Posted January 7, 2019 Report Posted January 7, 2019 If you are getting 12V at the plug your problem is between the plug and the bulb (i.e. the wiring in the housing, socket or the bulb itself), has nothing to do with any other component. I would start by connecting the bulb to a 9V battery and confirm its working. 9v should be enough to light it up although it will be dim. If you happen to have a 12V battery laying around that's even better. Quote
Banshee802 Posted January 7, 2019 Author Report Posted January 7, 2019 Just put brand new bulbs in and still doesn’t work. Checked for continuity between all three cables and it beeps for all. Not sure what else could be happening. Does the taillight have to be plugged in to complete the circuit?Sent from my iPhone using Tapatalk Quote
ginger Posted January 7, 2019 Report Posted January 7, 2019 tail light does not. voltage regulator you want to make sure it is working or it will pop the bulbs quick. Quote
Banshee802 Posted January 7, 2019 Author Report Posted January 7, 2019 It’s working, won’t make over 12 voltsSent from my iPhone using Tapatalk Quote
Banshee802 Posted January 7, 2019 Author Report Posted January 7, 2019 Anything else that could prevent them from working? There are no fuses on the bike. And I already tested the light switch and everything works thereSent from my iPhone using Tapatalk Quote
Banshee802 Posted January 7, 2019 Author Report Posted January 7, 2019 Well... this makes absolutely no sense but I swapped which side the lights were on and they now workSent from my iPhone using Tapatalk Quote
AKheathen Posted January 7, 2019 Report Posted January 7, 2019 Probably bad grounding.they can read good unplugged, but drop off when loaded.Sent from my SAMSUNG-SM-N915A using Tapatalk Quote
