Ewell Posted January 1, 2019 Report Posted January 1, 2019 (edited) Ive got one of Joes Molinari2-5 N down overrides. The previous owner tossed a modded shift star in it and forgot if he got it cut down for the 2-5. Is this okay to run or do i need to trim off the pegs for 1st and 6th.. Quote Edit Edited January 1, 2019 by Ewell Quote
375hp banshees Posted January 1, 2019 Report Posted January 1, 2019 It'll have to be correct one to work joe shoulda sent one with Quote
Ewell Posted January 1, 2019 Author Report Posted January 1, 2019 Would i be able to get another one from him? The guy changed it Quote
375hp banshees Posted January 1, 2019 Report Posted January 1, 2019 Yes, iirc theres more than just trimming off pegs. detent has to be relocated also, iirc, been a while Quote
Ewell Posted January 1, 2019 Author Report Posted January 1, 2019 I dont really know what else can be done to it, other than rounding the corners to make a smoother transition. And I talked to Joe and he said running a shift pro kit which comes with the detent arm would be fine. Just would be best to run the stock spring so i cant see any work being done to the detent arm.. Quote
camatv Posted January 6, 2019 Report Posted January 6, 2019 full length star OEM spring, OPTIONAL roller bearing detent.. only way i would run it. Quote
375hp banshees Posted January 6, 2019 Report Posted January 6, 2019 Agreed but not Stock, On a n down 2-5 Quote
