Ewell
Everything posted by Ewell
  1. I’ve got a 10 super cub and needing straight cuts for it. What ratio should I go with? It’s a 300ft track bike.
  2. I dont really know what else can be done to it, other than rounding the corners to make a smoother transition. And I talked to Joe and he said running a shift pro kit which comes with the detent arm would be fine. Just would be best to run the stock spring so i cant see any work being done to the detent arm..
  3. Ewell
    Shift star
    So i know how the override works, etc. Whats done to the shift star threw the process?.. Just cutting the studs on the star where the gears arent needed? Like a 2-5, Wouldn't that have 1st and 6th taken off the studs on the star?
  4. Would i be able to get another one from him? The guy changed it
  5. Ive got one of Joes Molinari2-5 N down overrides. The previous owner tossed a modded shift star in it and forgot if he got it cut down for the 2-5. Is this okay to run or do i need to trim off the pegs for 1st and 6th.. Quote Edit
  6. Ive got one of Joes Molinari 2-5 N down overrides. The previous owner tossed a modded shift star in it and forgot if he got it cut down for the 2-5. Is this okay to run or do i need to trim off the pegs for 1st and 6th..
