What's up Banshee fam!
What size domes and timing would you recommend for a setup like this,
421 Serval dune port --> currently running 24cc 100LL 7*
Sniper inframes
33pwks (can't remember jetting at the moment)
VF4's
yada yada yada
Originally had it on 91 pump gas with 4*
Thanks in advance!
If you dont raise the compression, you doenst need 100LL.
100LL is safe to about 165lbs static comp, so i "guess" 22-23cc can get you there.
What's the static compression with your 24cc?? About 140???
Envoyé de mon SM-G965W en utilisant Tapatalk
My tuner said with a higher timing the 100LL would work just fine with these domes. Given my squish .050", I'll be okay but I think it would be safer to run smaller domes right?
Sent from my SM-G960U using Tapatalk
I was running my 421 Serval on 21cc Domes, 0.055" squish, a 1:1 ratio of 91 and 100ll, and using curve 3 on a Dynatek, which is 15* at 10-12K rpm (similar to +6).  Elevation 1500ft.  Didn't have any deto.  I forget what my static compression was, though.
Currently running 91 octane on 24cc domes, 0.045" squish and 13* at 10-12K (similar to +4)  I honestly haven't bothered checking comp on this setup.
These setups used Shearer SBIF and PWK 35s.
Hopefully this helps a little
  • Like 1
0.050 is on the safe side for sure.
What is your static compression with 24cc???
Claude, just checked compression. left side 163, right side 170.
So keep the 24cc.
Thanks for the input.
