ginger Posted December 4, 2018 Report Posted December 4, 2018 your guts came out of the caps. you you arent getting a good connection causing your rough idle, dont run it like this or it will hurt the motor. Options are new wire caps, or a new coil. Honestly I cant believe you got 2 years out of plugs, Normally mine are changed every couple weekends of riding, Quote
dttuner Posted December 4, 2018 Author Report Posted December 4, 2018 Got it. I'll spring for a coil to be sure. $100 for oem coil is normal? Quote
dano3 Posted December 4, 2018 Report Posted December 4, 2018 21 minutes ago, dttuner said: Got it. I'll spring for a coil to be sure. $100 for oem coil is normal? Yes. I bought this combo https://www.ebay.com/p/NGK-Spark-Plug-Cap-Ignition-Coil-Genuine-OEM-Yamaha-Banshee-Yfz350-YFZ-350/23009165500?iid=191804903147&chn=ps Quote
camp0429 Posted December 4, 2018 Report Posted December 4, 2018 You can get new caps that screw right onto your wires from any parts store. Can't remember the NGK number for sure, (I'm at work now have new caps at home in the box with part number on it)but its like LB05EF? or something along them lines, You can get standard caps or with 5k resistor. Quote
dttuner Posted December 4, 2018 Author Report Posted December 4, 2018 1 hour ago, camp0429 said: You can get new caps that screw right onto your wires from any parts store. Can't remember the NGK number for sure, (I'm at work now have new caps at home in the box with part number on it)but its like LB05EF? or something along them lines, You can get standard caps or with 5k resistor. NGK TB05EMA? Quote
camp0429 Posted December 4, 2018 Report Posted December 4, 2018 21 minutes ago, dttuner said: NGK TB05EMA? Pretty sure its an LB05F or E. One you can use with the little cap screwed on the plug and the other you have to take that cap off Quote
dttuner Posted December 5, 2018 Author Report Posted December 5, 2018 Ok, so got lucky and linked-up with one of our members on the Facebook BansheeHQ page. OEM coil/wire/plug set shipping out to me tomorrow Thank you! Quote
ginger Posted December 5, 2018 Report Posted December 5, 2018 FYI not many members post on the facebook page, as it is mainly random idiots lol. Quote
ZillaFreak Posted December 5, 2018 Report Posted December 5, 2018 https://www.denniskirk.com/ngk/lb05f-spark-plug-cap-lb05f.p2051.prd/2051.sku?utm_source=google&utm_medium=cse&gclid=Cj0KCQiAi57gBRDqARIsABhDSMrwScndZK97nCeTz3MbxDZL4nMq-44aWS1K11tv9jI3zNCNALExU9saAnr6EALw_wcB&ad=228600803220 Quote
