Banshee508 Posted November 29, 2018 Report Posted November 29, 2018 Hi yes i was thinking on putting some of his onto my shee but was wondering the best way to do it https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F323206054387 thanks for any help Quote
ZillaFreak Posted November 29, 2018 Report Posted November 29, 2018 Looking at the ad, says it runs on 90-130VAC. This sounds like it is going a house outlet. A banshee puts our around 9-13VAC, a tenth of the ratings. If you are looking at how to run them, clear zip ties. Quote
Banshee508 Posted November 29, 2018 Author Report Posted November 29, 2018 It say u need a inverter to run in a car so the inverter is to switch from dc to ac right So it should kinda work with the 9-14v ac that the shee puts out? The electrical part is not my strong suit if you know what i mean Sent from my iPhone using Tapatalk Quote
ZillaFreak Posted November 29, 2018 Report Posted November 29, 2018 The listing is just shit. It says power supply is 12VDC. Then says voltage 90-130VAC. Find out from them what they actually work on. Quote
Keno Posted November 29, 2018 Report Posted November 29, 2018 El wire uses high frequency (like 2000 to 5000 hz) ac to illuminate. There are inverters that can power those off 2 AA batteries. Just look for a 12v inverter for el wire. Quote
Banshee508 Posted November 29, 2018 Author Report Posted November 29, 2018 (edited) Ok will do an if they say 12v dc then i just use the inverter to switch from. Ac-dc an how it would i hook it up to a power wire or thanks Edited November 29, 2018 by Banshee508 Quote
Keno Posted November 29, 2018 Report Posted November 29, 2018 I just checked the listing. It comes with a 12v inverter. Just connect that to your dc conversion on the banshee. The inverter will step it up to the correct voltage and frequency. Quote
ZillaFreak Posted November 29, 2018 Report Posted November 29, 2018 Just saw the invertor, I was thinking rectifier. An invertor takes DC and converts it to AC. Might mean the voltages is 12VDC and converts it to 90-130VAC. So on a banshee, you would need a rectifier to convert the banshee's 12VAC to 12VDC then the invertor converts it back to AC. Quote
Banshee508 Posted November 29, 2018 Author Report Posted November 29, 2018 23 minutes ago, ZillaFreak said: Just saw the invertor, I was thinking rectifier. An invertor takes DC and converts it to AC. Might mean the voltages is 12VDC and converts it to 90-130VAC. So on a banshee, you would need a rectifier to convert the banshee's 12VAC to 12VDC then the invertor converts it back to AC. Ok so i would need 12v rectifier an then the supplied inverter that comes with the kit an hook it up to a power source and it should work Quote
Banshee508 Posted November 29, 2018 Author Report Posted November 29, 2018 Just now, ZillaFreak said: Yes Ok Thank you for the help Quote
dttuner Posted December 5, 2018 Report Posted December 5, 2018 Please post pics, if this works. Especially in a dark room 😎 Quote
Banshee508 Posted December 6, 2018 Author Report Posted December 6, 2018 I will do but it may be a little bit before i get too it have it torn down for some maintenance Sent from my iPhone using Tapatalk Quote
