Hey gang, I have purchased a 2-1 set up from a forumer that came with a 34mm PJ and I need a starting point for jetting it. My motor has Rad Valves, T-6s, stock bore and stroke, and I ride between 0-1000' at 60-80 degrees. The carb came with 215 main, 60 pilot, and EEK needle.
Thanks
  • 3 weeks later...
  • 2 weeks later...
Yes I have it dialed in pretty well actually. I just need to bump the pilot up one more size is all. Im at a 52 pilot and an EEK needle on 4th slot right now which seems awfully large for my stockish motor. I have a pod filter I am using until I buy the 2-1 air box adapter, so I assume the pod filter requires much richer jetting to run correctly.
I am replacing this PJ with a PWK the first chance I get.
