kakuschke91 Posted July 7, 2018 Report Posted July 7, 2018 so ive I put together my motor 4 stock cylinders with an extreme port I used yamabond on the rubber plugs and on the dome o ring and no matter what im getting the same leakdown bubbling up into the rad ive taken it apart and redone it twice same thing any oppiniions Quote
sheerider11 Posted July 7, 2018 Report Posted July 7, 2018 so ive I put together my motor 4 stock cylinders with an extreme port I used yamabond on the rubber plugs and on the dome o ring and no matter what im getting the same leakdown bubbling up into the rad ive taken it apart and redone it twice same thing any oppiniionsCheck for burs and also see if the exhaust was ported to much could have broke into the jacket. I'm not sure about the transfers. If they come near enough the coolant jackets. Sent from my SAMSUNG-SM-G891A using Tapatalk Quote
sleeper06 Posted July 8, 2018 Report Posted July 8, 2018 Transfer or boost port would be my guess if something went through. How does the decks of the cylinders look? What steps and prep did you do for glue to stick and most importantly how long did you let it set up before pushing air in. If sealant isn’t 100% cured it will push out very easily under pressure Quote
kakuschke91 Posted July 17, 2018 Author Report Posted July 17, 2018 long delay went on holidays I found a pin hole from the ports into the coolant jackets on the intake side so I sent the cylinders back I ordered parts in may to do the motor its bin a pain in the ass its at least 8 days for shipping goin back on forth I feel like Im not goona get much ride time in get snow in October sometimes September Quote
kakuschke91 Posted July 31, 2018 Author Report Posted July 31, 2018 i had it done through b p racing Quote
Toybreaker Posted August 1, 2018 Report Posted August 1, 2018 is the top of the cylinders flat? are the cool head components flat? Start with the easy shit first...... Quote
ZillaFreak Posted August 1, 2018 Report Posted August 1, 2018 Dont use yamabond on the o rings or plugs. Quote
kakuschke91 Posted August 2, 2018 Author Report Posted August 2, 2018 What’s the reasoning and what should I use Quote
ZillaFreak Posted August 2, 2018 Report Posted August 2, 2018 It isn't needed and you shouldn't use anything on them. Quote
