Banshee508 Posted June 29, 2018 Report Posted June 29, 2018 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F153021976746 is this a good kit? thanks Quote
Banshee508 Posted June 29, 2018 Author Report Posted June 29, 2018 23 minutes ago, Banshee508 said: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F153021976746 is this a good kit? thanks Or this https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F312068060242 Quote
Toybreaker Posted June 29, 2018 Report Posted June 29, 2018 1 hour ago, Banshee508 said: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F153021976746 is this a good kit? thanks No 39 minutes ago, Banshee508 said: Or this https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F312068060242 Better, but still, no You are moving up to a 4mm crank. You need the cylinders worked to get the port timing optimized for the extra stroke, domes cut to use stock cylinders and you won't be able to reuse the stock 64mm bores for long. just get ahold of a site sponsor (I have been plugging driveline a LOT lately, this is the route i am taking on my bike next season) and have a REAL conversation as far as real use and expectations. You will be very happy with the results. Quote
Banshee508 Posted June 29, 2018 Author Report Posted June 29, 2018 Ok thanks i will not get those an i am tight on money so cant spend it all at once to have it done i have to accumulate slowly and why wont i be-able to use the 64mm bores for long Quote
Toybreaker Posted June 29, 2018 Report Posted June 29, 2018 (edited) If the bike has any hours at all, the bores probably are out of round and tapered. 2 strokes are actually pretty forgiving with fresh rings on worn out bores, for a redneck repair it works. But it is a grenade waiting to go off. ( i am not saying it is an acceptable repair, just saying it can work) besides, are you sure your bike is on the factory bore? Edited June 29, 2018 by Toybreaker Quote
Banshee508 Posted June 29, 2018 Author Report Posted June 29, 2018 Ahh ok i see now an Ya my shee has tons of hours been riding it for like 8 years now and havnt touched the inside of the motor and im not sure if they guy i got it from did any work to the inside either but it still fires right up in 1-2 kicks Quote
Banshee508 Posted June 29, 2018 Author Report Posted June 29, 2018 Sent from my iPhone using Tapatalk Quote
sleeper06 Posted June 29, 2018 Report Posted June 29, 2018 My advice is wait till you have the money to do everything at once internal wise. There is a ton of little things that make a reliable build. Opening up something that’s never been touched is a domino effect waiting to happen. The key part is knowing what to look for wear wise on the internal components, could make or break the budget. Get it out of your head thinking your gonna piece it together or that’s what it will be” a piece “! Remember you can go broke saving money . 1 Quote
Banshee508 Posted June 29, 2018 Author Report Posted June 29, 2018 25 minutes ago, sleeper06 said: My advice is wait till you have the money to do everything at once internal wise. There is a ton of little things that make a reliable build. Opening up something that’s never been touched is a domino effect waiting to happen. The key part is knowing what to look for wear wise on the internal components, could make or break the budget. Get it out of your head thinking your gonna piece it together or that’s what it will be” a piece “! Remember you can go broke saving money . K ill just hang in there an wait till it grenades itself when ever that happens an just send it to fast or hjr Quote
kawa110 Posted June 29, 2018 Report Posted June 29, 2018 Cost more rebuilding a “grenaded engine” then one that is worn..... Quote
Banshee508 Posted June 29, 2018 Author Report Posted June 29, 2018 1 hour ago, kawa110 said: Cost more rebuilding a “grenaded engine” then one that is worn..... I know lol but how to tell if its worn with out taking it apart seems to rip like it always has since i got it in 06 Quote
sleeper06 Posted June 30, 2018 Report Posted June 30, 2018 Do a compression test and a pressure test and report back Quote
sleeper06 Posted June 30, 2018 Report Posted June 30, 2018 Being that it’s stock these tests can give a Lil insight into the condition of the top end and engine seas/gasket Quote
kawa110 Posted June 30, 2018 Report Posted June 30, 2018 “Grenading” a engine ensures you will not want to use most of the internal components let alone the cases and jugs. If you don’t care about any of that....Keep “ripping” ur engine and start saving to build a complete new engine, used clean caseswpuld be good start. Quote
Banshee508 Posted December 2, 2018 Author Report Posted December 2, 2018 Do a compression test and a pressure test and report back This is what i get form the left an right is a tad higher Sent from my iPhone using Tapatalk Quote
